It is currently Sat Aug 02, 2025 11:42 pm
 Post subject: KTM9 Over Lacquer?
PostPosted: Sat Dec 13, 2008 7:31 pm
Last Name: Cyr
City: Roseville
I have a bass body that has two coats of McFadden's Sanding Sealer on it so far. But I'd like to switch to KTM-9 waterborne lacquer now. Can I just apply it over the sanding sealer?
Thanks!
---Steve
 Post subject: Re: KTM9 Over Lacquer?
PostPosted: Sat Dec 13, 2008 7:48 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I'd slap on a coat of shellac first.
Dave F.
Cambrian Guitars
PostPosted: Sat Dec 13, 2008 10:08 pm
I've never tried it but conventional wisdom is that waterbourne under solvent based is OK but not the other way around. Solvent based finishes continue to off-gas for a long time. If you put an impervious film over it, the gas can't escape and problems arise.
http://www.chassonguitars.com
PostPosted: Sun Dec 14, 2008 1:56 am
Last Name: Cyr
City: Roseville
So it sounds like I should strip off the sanding sealer, yes? I guess I'll attack it with some lacquer thinner tomorrow.
Thanks y'all!
--Steve in Roseville
---Steve
PostPosted: Sun Dec 14, 2008 4:01 am
Last Name: Fifield
City: San Jose
I would just sand it (220 grit) back to bare wood again, not strip it chemically. The little bit of sealer left in the pores of the wood isn't going to be an issue IMO. I would then seal it with shellac before moving on to finish.
Dave F.
Cambrian Guitars
PostPosted: Sun Dec 14, 2008 11:21 am
How about if you do a test piece on some scrap and see if it works. Then you could report your findings to help others in the future.
PostPosted: Sun Dec 14, 2008 9:48 pm
Last Name: Cyr
City: Roseville
Dave F.
Sounds easier and less toxic than my lacquer thinner approach, so that's what I'll do. I don't have any shellac - is that a necessary step?
---Steve
PostPosted: Wed Dec 17, 2008 11:50 am
the thought process is to seal the nitro and give a layer that the waterborn will adhere to . But frankly I too fear that the nitro is still gasing which will cause big issues.
If me I would finish out in nitro but if you really want to go to waterborne then I would remove all finish and start over if i was to put KTM9 on this guitar
PostPosted: Fri Dec 19, 2008 3:10 am
Last Name: Cyr
City: Roseville
That's what I've done - sanded it down to bare wood. The next step is to seal it with epoxy in preparation for the KTM-9. I'll do that tomorrow, then start applying KTM-9 on Saturday.
Thanks again for the advice!
--Steve
---Steve
